- Yorkshire
- Kevin
- Yorkshire
I built an android app for my own E51 (a S1 2002 Highway Star on LPG) to allow me to read / reset fault codes without a JOBD reader or using my laptop, anyway the functionality has grown to be a full on e51 Elgrand diagnostic / health monitoring tool, It's turned out well enough that I think it could be useful to other members, so I'm happy to share it.
I should say up front that I'm not an Elgrand expert & relied on this forum for advice to develop the app. The E51 uses Nissan's own Consult-II protocol rather than generic OBD-II, so I logged and decoded / reverse engineered my own van's Consult-II signals (a bit of a pain to do & may contain misinterpretations of signals / data). There's a lot of knowledge on this forum that I don't have, and your input would make a real difference to finishing it properly & rolling out to the forum.
What it does
Looking for beta testers
So far it's only been tested on my S1 van. Before I share it with the forum properly, I'm after a handful of E51 owners to help iron out the creases. Petrol and LPG vans are both welcome. It would also help to hear from anyone who knows these vans well and can tell me when a verdict or a reading doesn't look right. There's a Report button in the app that bundles up everything I need.
Nothing leaves your phone unless you choose to share it. It's free, with no account and no adverts, and it's an independent project that I'm happy to share with the forum if useful.
If you're interested, PM me and I'll send you the test link - I think I'll limit it to a few initially to make sure others can connect / use as I do.
Cheers, Kev
What it does
- How: Downloads from Android Play Store, runs off your android headunit or phone / tablet. Connects to a (good) Elm327 or STN OBD dongle (I used a vLinker MC+), can also connect by VAG K line cable.
- Fault codes: reads and clears codes from the engine, gearbox, ABS and airbag modules off your phone / headunit.
- Cat monitoring: compares the rear lambda sensors with the front ones, and bank 1 with bank 2, and tracks the trend over weeks to attempt to flag the early signs of a failing cat.
- Health checks: fuel trims (petrol and gas), all four lambda sensors, alternator and battery (including the voltage dip while cranking), coolant, gearbox temperature and warm idle. Each check gives a plain-English verdict and the figures behind it. For best output the app needs to run on every drive and data collects over time to show trends.
- MPG: live, per trip and per tank, kept separately for petrol and LPG. It calibrates itself from data pushed by the van.
- LPG gauge: tracks gas used and remaining, with a range estimate (no more resetting trip counter).
- Trip log: every drive is logged with distance, fuel and cost.
- Head-unit dashboard and Android Auto: a live view of the van with every reading shown. The head unit or phone connects by itself every drive.
- Workshop: service and MOT reminders, a soft-tyre check using the ABS sensors, and active tests (these only run when the van is parked and idling).
- Garage report: Health report & log outputs you can share and analyse away from the van.
Cheers, Kev
