Door seal damaged
Paulf
London
Br33sa
Paul
London
The rubber door seal on my '07 Elgrand is torn and damaged. I am getting water ingress to the compartment under the Drivers floor so I am assuming this is where the water is entering. Has anyone replaced this and if so. how difficult a job was it.
I would pull the rubber off, clean, put silicone in the grove, bang it back on, hopefully your done.
If replacing seal, I would purchase a good second hand one from a breakers ( you'll know it fits) do the same with silicone, I have purchased plenty stuff the seller says fit's only to find out it doesn't.
