Any ideas what this is for
If you don't need to use it to start yours, but you have the receptacle as pictured above, it's probably been deactivated/linked out.
Only issue may be will have a parasitic drain on the battery if not fully removed, and we have enough of them as it is..
Thanks, don't need it as it is on the spare key fob do get battery draining, when I bought 3 years ago was given a spare key, taken 3 years to realise spare fob works but key inside fob does not work in ignition, so do I have a key to another Elgrand 😀 only found out because original fob has stopped working
