Top radiator hose blown help !!
Can't Be Arsed
E52 Owner
Yorkshire
Sheffield
Jonny
E52
Yorkshire
My radiator top hose had decided to spring a leak.
E52 2012
Trying to find a replacement but having major issues trying to get hold of one.
Tried JDM but they don’t seem to stock them .
Any advice would greatly appreciated
I’m at my wits end trying to find one that will fit.
Don’t know if yours is 3.5 or 2.5 etc but have a word with these guys
https://www.elgrandcarparts.com/Nissan-Elgrand-upper-hose-radiator-right-angle-88628-2194-2121-44-d
Seems the highlighted one comes up in most searches ( differing part numbers but always the 90 degree bend ?).
If so I would think it could be got from most parts suppliers who will usually have an oddments bin/box
These guys do 90deg rad hoses in all size.
Just on a side note… I did buy the wrong colour coolant (pink) instead of blue to top up the rad system.
Could I have caused this issue because of a blonde moment 😩
Mixing different coolants can make them congeal and cause blockages. Depends on the spec of the coolant rather than the colour.
Going to flush the system and put in the correct (blue) coolant in, hopefully this will cure the issue
Flexible radiator hoses that can get you out of trouble;
although for a short elbow one of the automotive silicone hose manufacturers can probably soon provide something that wil lfit.
