- edinburgh
- james
- Scotland
The other day, before I went on hols, well meant to be hot hot, so took the plunge.
Went to farmer autocare, £60 to get the old girl done, never been done in my ownership, some 4 years!, yes it was cold but not cold, cold, but Elgrand only goes to 18, in jockland it doesn't get that hot anyway, well things change.
So, guy does the stuff, says, took pressure, no problems, removed then filled, said the amount, but just numbers to me anyway
No charge, it was free.
Said not cold enough, thinks something wrong with condenser.
So, me thinks it's not to bad, got home, pulled grill off, well the bottom of the rad doesn't look so great, lot of aluminium about the bottom shelf and quite a few damaged all along the bottom half, top looks good, cutting a long story short, I'll replace the rad, I'm quite surprised that the rad does the engine coolant, the transmission and also the ac!!
By the way the weather wasn't hot, so didn't need the supper cold ac, just the normal heater, so cost me nothing, but at least I found my rad is on the way out, so I'll change soon
