Auxillary does not work and Error Code E202 on Auxillary screen
Easiest solution is select aux on both big and little remote if you have them or pull the plug from the little box behind where the rear cigarette socket is and jump the plug using staples or by pulling the line out and soldering them together and taping-up.
There is a detailed solution within this forum you can search for.
Thanks @Nevillerover.... seems like im going to have to get techy
