- Oswestry
- Justin
- E50
- Midlands
Where would I get these from? I also am about to suffer this nightmare
I made them , I can send u the sizes of it helps ,Where would I get these from? I also am about to suffer this nightmare
Ball joints and drop link are very common on these to cause clunk's. I've had them replaced on mine several times over the years.Well had the strut top replaced......that didn't fix the clonk,so will have to do more investigation as to what is causing it. I am wondering if it's the drivers door hinge as it definitely needs fixing as the door drops about a quarter of an inch when you open it. It could also be the anti roll bar bushes or the bottom ball joint or the track rod end etc etc etc. Have received the service kit so that's booked for Wednesday . Also today stuck all the disabled/ medical equipment/ oxygen warning stickers on. Ruins the look abit but must have them in place.
They is a easy mod with a washer to stop the door dropping and line it up for when closingWhere would I get these from? I also am about to suffer this nightmare
Hi Ron. I love your pod!Hi, My name is Ron and I drive a 2006 Highway Star. I have been a member for a wile but never posted anything up until yesterday. I have been checking in on the site from time to time to see what everybody is up to. Here is what I have done to mine. Mine is pretty much standard but I fitted a kitchen pod in the back and I am using it as a day van. Let me know what you think. Thanks.View attachment 54003View attachment 54004View attachment 54005
Hi Ian,Hi Ron. I love your pod!
Is it removable?
I’d love to do something similar using the seat rails as fixing points When holidaying, but remove it when not travelling.
Thanks.Hi Ian,
It is removable and it has 3 tie down points. I upgraded the lashing rings to metal ones and hook and eye turnbuckles are used to secure the back. At the front I have used the seat rails as a fixing point. Hope this helps.
Thankyou, I hadn't thought of that , I hope the hinge pin isn't worn as some on here have reported.I will certainly have a look at that when the door comes off !.They is a easy mod with a washer to stop the door dropping and line it up for when closing
Thankyou but I don't have the facilities to make something as good as that.....but you have awoken my fertile imagination and I have several ideas to try out.After all after making these, some hinge pieces shouldn't be to hard lolI made them , I can send u the sizes of it helps ,
Those were going to be my next point of investigation, I've had one let go when I was much much younger, a very hairy moment or two, don't think I want that to happen now at my age, don't think my nerves would handle that to well lol. And the Elgrand is a lot bigger than a Morris Marina !!!!!Ball joints and drop link are very common on these to cause clunk's. I've had them replaced on mine several times over the years.
So why is the door coming off ??? Hinge pin is pressed in , like a big rivot, only way is to cut it and knock out, I made new ones like a bolt , to lift door undo bottom hinge take nuts right off , get someone to lift door till door studding just clears hinge , drop a washer on bottom stud drop door studs back into hinge and tighten nuts back on , check door for height if still low repeat again but I’ve only had to one washer , if u need brass bushes give me a shoutThankyou, I hadn't thought of that , I hope the hinge pin isn't worn as some on here have reported.I will certainly have a look at that when the door comes off !.
Many thanks, sounds a lot different to car door hinges I've worked on before lolSo why is the door coming off ??? Hinge pin is pressed in , like a big rivot, only way is to cut it and knock out, I made new ones like a bolt , to lift door undo bottom hinge take nuts right off , get someone to lift door till door studding just clears hinge , drop a washer on bottom stud drop door studs back into hinge and tighten nuts back on , check door for height if still low repeat again but I’ve only had to one washer , if u need brass bushes give me a shout
I’ll get u a pic of hinge , I’ve got a set and send u some pics what they look like in bitsMany thanks, sounds a lot different to car door hinges I've worked on before lol
