- Co. Durham
- Andy
- North East
Looks like @Bob Edwards paint is going on a road trip again.
Ok I'll post it on. Might take a while for delivery though.Mate, I'll borrow that off you before you hand it back.
Wednesday at 7:12 PMIn 2012 i re-carved the dashboard of a Toyota Aurion to house a tablet, i was happy, even the Tesla tablet wasnt around in Australia until 2014. Over the years the tablet got slow and the thought of modifying again to a new tablet’s physical dimensions just never happened. The separation of display and cpu was essential in order to survive the test of time.
The Elgrand screen is 720x480, has three composite inputs (rev cam, side cam, TV Aux) and one RGBS input (Navi/DVD), which all go via the BCM? (behind speedo), and then via ribbon cable to LCD display.
Idea was to convert the LCD image (LDVS signal on ribbon cable) to HDMI, and display the original image on a new touch screen. I could convert Comp & RGBS (OUT) to HDMI but air con temps and any warnings didnt show up.
The only option i could find for converting LVDS signals were kiosk screen test devices and they wouldn’t support such low res screens such as the Elgrand screen. Dead end without liaising with an Alibaba factory.
I needed to retain Air Con settings and Warning messages.
After fitting a four camera 360 birds eye view kit with the original screen i realised i was missing the OEM reverse camera steering lines on the display.
The original screen had to stay.
The next hurdle could be solved with a hidden bluetooth car amp, most of which dont do calls, just music, they do exist but i had a Clarion head unit amp i decided to dissect as i liked the control button (rotate, click, up, down, left, right). The position of which I'm really happy with.
The display i went for is abit over the top for res, 2560x1440 - i was thinking android os with extra screen height for task bar at the bottom (like 1280x720 vs 1280x800) but going over 1080 with an uncommon res lends to some annoyances. Most HDMI devices expect 720 or 1080.
I have two Pi4 4GB, one running Open Auto Pro kinda as the head unit, the other Pi is an Android image (for Torque ODB) but i think a dedicated Android TV style box might be better, just not sure which ones are usb compatible for touch (& GPS?).
Hacking the buttons was a puzzle in itself, surprisingly the buttons aren't all input-to-ground-signals for switching, so i de-soldered the unused small square push buttons, glued back at right angles, soldered new wires that went to a new connector on the back.
Part research and sourcing took 6 months, cabling preparation was a spreadsheet and at least 25 extra cables (7xHDMI, 12xUSB, . Have all the convertors and cables i could ever need eg - the HDMI version of the 360 birds eye view uses the same cameras so should be just and black box swap. Also run RCAs and power to the back ready for a second battery, dedicated amp with speaker upgrade but its not urgent.
Also added the cables for a second new screen as a HUD showing the ODB…
Added IR repeater for any remotes (if needed) in the plastic around the rearview mirror, and an emitter for reproducing any original Nissan IR triggers firing at the overhead receiver.
Will add more detail as i go
Music is definitly important to me... I have already tried to have my radio changed, but the guy told me it wasn't possible - I think he said it was due to the amps?!?! He said it was only 11 and I need 12... Need to check this out and get clarity... How many speakers are there in your Elgrand? Do they all have the same number?Great idea Madfish
I realised that my speakers aren't up to spec, so need to get them replaced asap. But haven't actually done anything as of yet!
Wow look how much better it looks with the splitter on than without it!!!Wing mirror fixed front splitter fitted and rear brakes almost sorted .. been a daisey day .. the highs n lows or Elgrand ownership and modding .. not happy with the colour match of the splitter and still have one more bit of work to do for the rear brakes View attachment 53888View attachment 53889View attachment 53890
Shocking! You of all people....i have done nothing it will be arriving dirty tomorrow not had time
