Will "elf and safety" not have a problem with them having points on?
Andrew, I carefully sanded them to give the impression of a point without actually being able to harm the little bastards cherubs.
BTW I've got loads of pallets so taking orders for Xmas 2023 👍 🤣
Fitted an additional reverse camera, which i got free with a hu. Quality is better at night compared to the factory.
where abouts did you fit it ? as I am doing the same but not sure where to install it...any pics mate would be ace.
my rear-facing dash cam is screwed to the bottom of the top stop light
Ye will have to find a way to post pics. Basically, ive sort of stuck it with double sided tap(i know not ideal but still working on the work around) under the bit where you open the boot, still has space to put fingers into to open the boot button. And frd wire through one if the number plate lights. Done it this way due to getting the angle i wanted, so it points down and i see the end of the rear bumper.
how did you run the cable...
behind the number plate light then upthe trim right to the top edge then through the rubber(top left of the boot, when the boot is opened) then doen the pillar to the lights. Then from the rear light to the front stereo through the side steps.
Allen my cable runs between the roof liner and side trim pushed in with a plastic trim remover then between the roof liner and front screen the plug cable goes from the cigarette lighter socket pushed between the dash and air vents up the a pillar and across the roof liner and screen only wire showing is 6" at the rear and 6" at the front
Thats another of doing it!
fab that;s what I thought... you got a pic of the rear bit ?
Allen here are the pics hope you get the idea IMG_20221204_173322.jpgIMG_20221204_173432.jpgIMG_20221204_173419.jpgIMG_20221204_173354.jpgIMG_20221204_173349.jpgIMG_20221204_173453.jpg
