- south yorkshire
- Dave
- Yorkshire
Thats the same as I use and it's a very close match.Found this stuff to be close although this time it’s in different cans ( will see if it still matches in daylight later today)
Couldn't agree more. I'm well impressed with mine, and like the look of them tooI got some of those denso hybrid wipers today from euro car parts after recommendation on here. £24 for both and I can confirm they work perfectly and look like they belong on the Elgrand. Nice beefy body to them.
Forget the Bosch aerotwins now...
Link pleaseI got some of those denso hybrid wipers today from euro car parts after recommendation on here. £24 for both and I can confirm they work perfectly and look like they belong on the Elgrand. Nice beefy body to them.
Same happened to me when I fitted my Elementian middle box and decats.well i have found putting a slightly louder exhaust on my grand and a bit freer flowing im using more petrol its brought out the inner chimp in me as i push the loud peddle a bit more just to hear the rumble all in good fun on roundabouts and junctions
I have done almost exactly the same things, but I think the Bluetooth/ fm link seems to play at a lesser standard from the speakers. The dvd and cds are rich and full, the Bluetooth is way worse - is this just me or have you noticed this too?Managed to get the audio from my phone straight to the stereo with this handy little gadget
Phone attached to a magnetic mount in the vent just above, charging via a short Anker cable so quite neat/no wires trailing everywhere
Was very simple - paired gadget to phone via bluetooth, set frequency to 87.5 as there was nothing broadcasting in that band
Then set car radio to the same frequency (y)
Tested with music already on the phone, Spotify etc and all working great - ok maybe not audiophile quality but good enough
[edit]
not tested with sat nav yet
also apparently works as a hands free device for calls - not tested that either
Post in thread 'Michelin Wiper blades' https://forum.elgrandoc.uk/threads/michelin-wiper-blades.30616/post-426693Link please
Nice.Permanently installed my HDMI to RCA Converter behind the TV tuner, and fitted a panel mount HDMI and USB ports in the rear cubby for Chromecast and WiFi hotspot.
Elaborate please CharlesPermanently installed my HDMI to RCA Converter behind the TV tuner, and fitted a panel mount HDMI and USB ports in the rear cubby for Chromecast and WiFi hotspot.
I used a combination of a:Elaborate please Charles
cheersFound this stuff to be close although this time it’s in different cans ( will see if it still matches in daylight later today)
it was the power supply that was baffling me, cheers @cjholdingI used a combination of a:
3ft Right Angle RCA Cable
Panel mount HDMI and USB
Panel mount dual USB
The HDMI converter is just stuck to the back of the TV tuner with a double sided sticky pad.
I cut a notch in the trim above the VTR input to route the RCA cable behind the trim to the converter.
Then just drilled two holes for the panel mount connectors in the right hand side of the rear cubby and mounted them there.
I need to fit the power supplies, I have a couple of (probably fake) Griffin dual USB chargers that the cases split on which I plan to hard wire behind the panel to provide power to the three USB ports and the convertor.
To remove the trim panel, you need to remove the seat from the rail, and remove the hook by the sliding door, the rear tie downs and the trim clip in the rear cubby and two more behind the panel with the 12V outlet by pushing the dowels in the middle to release them.
