Under sealing, should I and who is good around SE Wales / M4 corridoor?
MrFoster
Wales
South Wales
Stefan
Wales
Afternoon!
The underneath of my e51 has clearly not seen a drip of underseal on Import two years ago.
Sadly it's showing a fair amount of rust. It looks to be only surface from light inspection.
I know from other threads there is a lot of controversy over sealing, as it can trap in water and make the rust worse. Potentially a fair amount of treatment is needed cleaning it back to metal etc.
Anyway, I'm a bit concerned over doing this myself in case I balls it up. So I'm looking for a company to take a look and do the job properly (if it can be rescued and is worth it).
I've contacted two companies - no response from either.
Can anyone recommend any advice or good companies? Ideally South East Wales / Bristol way?
Cheers
skystalker1
South West
Torbay
Richard
South West
I contacted two companies only one reply ,must have loads of work most places don't seem to want to do it ,mine is booked in next month for a waxoil £330 including loose rust /dirt clean off the more expensive one was around 1k and they was not to keen on doing it at all had had to chase them .Not many garages will do it these days due to the mess .
Stempy
Part of the furniture
South East
Trader
The Waterfront City
Stempy
South East
If you wanted to travel to Winchester then Adrian does a good job.
MrFoster
Wales
South Wales
Stefan
Wales
£1k... yikes that's steep. 😬 who was that with?
MrFoster
Wales
South Wales
Stefan
Wales
Hmm thanks @Stempy. Winchester isn't a million miles away. Who does Adrian work for, or does he have a website I can check out?
