- Co. Durham
- Andy
- North East
Good work Boris
How to: Check S15 Fault Codes - Paperclip Method
Whilst helping justin666 with his non-starting S15 last week, he showed me how to flash up fault codes on the S15 ECU. I wasn't aware it was possible to do this until last week so here's a quick guide for everybody else.. Nissan ECCS allows you to read any stored fault codes without any...www.silviaoc.com
Thank you) I know about the paper clip method, that's how I do the diagnostics) I need a scanner to see the characteristics, namely the high pressure fuel pump)Have a look here:
Think yours might be 16 pin sort but if 14 pin you can do with a paperclip:
Thanks a lot)) I'm fine)) New Year's bustle)Hi Boris hope your well I opted for the 14pin consult that plugs into my phone didn't fancy the Bluetooth version if you search Nissan 14pin consult on ebay both options will come up
Good luck with your project Boris look forward to seeing it along the way hope your keeping safe mateHello everyone .. Well .. The winter was mild and kind to us Siberians. Elgrand got new rust spots. The engine rumbles like from the factory, clearly, like a Swiss watch, only Japanese) electrical problems began, periodically losing contact with the engine speed sensor. Just in case, I bought an efi block from Japan.
Winter consumption of 13 liters per 100 km.
Inspired by English Campal. Today I bought plywood.
I am waiting for March 9, when the tools for woodworking will be delivered. I'll start creating..New item by Boris TheBlade
photos.app.goo.gl
The plans were like this, until February 24...
So....
.As always, sorry for my English.
And #stop the war...
