Hi @Tana Here’s info why you should have rears Decored & the different methods .
Tony Banks exhausts here in Leeds has Elgrand experience , he should be of help - all depends which option you choose .🙂
Hi
It jumps on the top of the list now. Thanks
So what is the Elephant in the room?
It's missing from all of these threads from what I can see.
Here it is - the Catalytic Converters are consumables.
Yes that's right.
They don't last forever.
100,000 miles or about 10 years on average!
Any car, any manufacturer, any model.
They are all about the same.
Thing is ours are not normal - they are on the edge of normal.
Blame what you like from any of the above reasons - design, fueling environment, take your pick.
They all/any may make some difference to the life expectancy.
Fact is (I'll say it again ) THE CATS ARE A CONSUMABLE.
They will degrade over time and need replacing.
So - how old is your Elgrand eh?
LIST OF AFFECTED MEMBERS
The problem
damage to the engine.
There are 3 main options.
But what about.......?
Is this legal?
Why does this need doing?
Hi there
After several weeks driving our imported E51 around we started hearing a rattling sound under the van. When accelerating slowly or going up the hill it would rattle towards the front of the engine. Took it back to the car dealer he said nothing to worry about, use the most expensive petrol. Noise will go away. Noise did not go away.
Took it to a mechanic referred to by Car Dealer - mechanic said there's hardly any oil - fill the oil should be no problem. Noise did not go away. Taking it back again today to leave at the shop as suggested by car dealer so mechanic can have a proper look and at the catalytic converter.
Any other reason this maybe occuring?
Is it something we should be concerned about?
Definitely take it back and maybe get you cash back.
Hi there
Not all rattles around that area are from the exhaust and not all exhaust rattles are due to a cat problem.. A rattle from the exhaust could just be an exhaust heat shield that's loose. But it is definitely worth getting cats checked.
Whoever told you that using the most expensive petrol would stop the rattle is going to be wrong.
The engine can sound rattly if it's low on oil but topping up didn't cure your issue. Even after the rattle is sorted keep an eye on oil level, see how much oil it uses in how many miles and see if the exhaust is smoky.
Posts crossed @Stempyuno and @dognero
The problem
Is this legal?
Hi,
I've heard so much about this problem and I note that every importer lists decoring or similar as part of their prep before selling the vehicle. I'd like to ask perhaps a really silly question. If these secondary Cats are fitted by the manufacturer, and they help make emissions cleaner presumably, Why don't people just keep them and have them serviced regularly so they don't cause an engine blowup? I don't know diddly squat about car mechanics, but I accept that many parts of my vehicle need to be changed/maintained routinely to keep it working correctly. I appreciate everyone's answers and opinions. thanks
Hi,
The problem is the front cats go and will not warn you first, they can just go and when the parts git the rear they back pressure and blow the engine, or large parts can go forwards from front cats and destroy engine that way
emissions are still fine after rears removed so why wouldn't you remove
Better prevent than replace engine afterwards...
The problem
Is this legal?
@animalmad1311 - “just” in case your rear CATS are still in place , (ring the dealer , maybe?)
- this is why they need removing 😉
Hi,
It matters not how much you service and maintain the vehicle, the front cats are a weak point and can destroy the engine in seconds if they let go and the secondary cats are still in place, which can happen with no warning. You could have the front cats replaced at regular service intervals but I don't think you would like the bill.
Does anyone have a mechanic/exhaust place who'll decore the rear cats in Sydney, Australia? Literally, every mechanic I've spoken to says that doing so would be illegal and they'd get into trouble for doing so, so can't do it - I've called over 20 places so far - perhaps from all the bogans doing it for 'performance' reasons and later getting their cars impounded and defect-listed.
If a mechanic won't do it you could do it yourself or ask a welder to do it.
Do the mechanics know that there are 4 cats (2 at the front and 2 at the rear) and you'd only be removing 2 of them (most likely the rears)?
Or you could just buy bypass pipes and do it yourself.
Which reminds me I'm doing a rear decat today. I recently finished the LPG conversion with vapour take-off, fitted it's towbar, changed plugs and PCV.
@Lpgc, unfortunately, I'm a full-time wheelchair user so can't get under the vehicle to attempt it (and lack the tools these days) - as far as it goes it seems an uncomplicated task, but sadly not one I can attempt these days. Great work with your LPG conversion and towbar - hope your decore/decat goes just as smoothly.
And yep, I've explained that the rear cats are just there for Japanese cold-start emissions laws and the vehicle passes Australian emissions tests on the front cats only.
than
Thanks for that link. Looks like my van had 2 recalls, but none implemented
Your car was found as a target vehicle for the following items.
numberContentTypeNotification date (start date)Implementation status
1​
Elgrand recalls Siberian
(part of vehicles produced from 2004 to 2007)
recall2019/02/14Not implemented
Two​
Elgrand's recall
(part of cars manufactured from 2002 to 2006)
recall2013/09/12Not implemented
thanks for this, i just looked mine up, although in japanese, i translated and my first one was done and the second not....
I started reading this 38 page thread, but had to go back to work.
Can I just check, I can decore the front cats without any MIL lights or engine issues?
Or is it just as safe and easier to do the rears?
You can decore front cats without any MIL light issues but make sure you don't damage the lambda sensors during the process or you will have MIL light on due to broken lambda sensors.
Decoring rear cats is definitely much safer than leaving rear cats in if you don't decore front cats... but decoring front cats is much better still, just a lot more work.
Arguably decoring all cats is safest. No cats = no chance of any cat failing. But you need to have an LPG conversion to pass MOT if you decore or remove all cats. I haven't heard of any rear cats failing yet (other than when they've been bunged up by debris from failed front cats). Maybe rear cats don't fail because they're not as close to the engine as front cats, or maybe it's because they're a different design, or maybe it's because the front cats normally do the brunt of the work before exhaust gasses reach rear cats. If it's the latter it could beg the question how will rear cats fair when front cats have been decored or removed, but at least there wouldn't be another cat behind rear cats for debris from failed rear cats to blog up and at least rear cats are further from the engine so if they blogged themselves up debris might not reach the engine.
There are aftermarket cats which nobody has yet had fail (in the X years they've had them fitted, where X is likely to be a small number). You'd probably want to price up having aftermarket cats fitted before deciding to go that route. Arguably new standard spec cats wouldn't have likely failed after X either, which could leave the question what happens after Y (where Y>X and where standard cats might have failed after Y).
My how to on decoring front cats on your driveway https://forum.elgrandoc.uk/threads/front-cats-decore.21762/#post-285765
