Thank youThere are a few clear options now.
For me - I chose front cat decore from Paul at Powerflow Cardiff (£240).
Plus LPG fitted by Simon @Lpgc
Now proven to be quite a good route.
Have a chat with dave at vine place, Elgrand dealer just up the A19 in wingate.Hi everyone, I've just been chatting to my father about getting his cats either de-cored or replaced, the question is, does anybody know of someone who can do this for him in the Middlesbrough area? Thanks.
Morning, would decating the front cats leaving the rears in place cause an issue for the sensors?We're into the can of worms again...
Why say move front cats back slightly? I'd bet the answer is because some on forum reckon the front cats are too close to the engine exhaust ports... (which imo may be a contributing factor). But with that said it then begs the questions - How far back should these new front cats be fitted (so they won't suffer the same fate as original cats)? If the problem was just the location of original cats (too close to exhaust ports) then instead of fitting new cats why not just fit a spacer between manifold and original cats (if front cats seem in good condition)? Does the suggestion to replace front cats with aftermarket cats and also to fit aftermarket cats further back in the exhaust (further away from exhaust ports) reflect a belief that the problem is due to both the original cats being prone to failure (even if they were fitted further back) and being fitted too close or just one of these?
If an Elgrand will pass MOT running on petrol with front cats decored and rear cats still fitted, why buy new front cats when original front cats could be gutted (no parts to buy just labour for decoring front cats)?
For those running on LPG, if an Elgrand will pass MOT with all cats decored, decoring all of them (no parts to buy) may give more peace of mind than any other option. No cats at all fitted means absolutely no chance of any cat failure in any circumstances.. In contrast, an engine problem such as a stuck open petrol injector or badly broken PCV valve (or burning oil for any other reason e.g. valve stem seals etc) could cause any cat to fail, a new aftermarket cat may suffer the same fate as original spec cats under such conditions and maybe even in the same amount of time.
I still think decoring rear cats will save the majority of engines in the case front cats break up. I agree this isn't a total fix and know there's still a risk of front cats blocking themselves up (and I believe I was among the first to say so). But I don't think there's enough evidence yet to know how well aftermarket cats will fare in future, perhaps especially not if they're fitted as close to the engine as original cats were. For the amount of time people have been replacing front cats with aftermarket cats (this started relatively recently?) we probably wouldn't expect new original spec cats to have failed since being fitted either. The best 'sports cats' are the least restrictive to flow of exhaust gasses but no cat flows as well as a pipe with no internal restrictions or as well as a cat that has been gutted.
My personal level of confidence in an Elgrand not suffering cat problems over the long term goes something like this:
Totally original spec exhaust, all cats in place 30% confidence.
Decat rear cats 80% confidence
Decat front cats leaving rear cats in place 97% confidence
Fit aftermarket front cats leaving rear cats in place 87% confidence
Fit aftermarket front cats and gut rear cats 93% confidence
Decat all cats 100% confidence.
Those figures assume no engine problems, they could change very quickly if there are any engine problems involving excess oil or fuel getting into the exhaust system. The only figure that would not change in any circumstances is the decat all cats option.
If someone asks me to decore rear cats at same time as LPG conversion I charge £100. The short passenger side rear cat doesn't need to be cut into anyway, it's short and straight enough that it's internals can be accessed and removed from the ends. The drivers side rear cat does need to be cut into to decore, it is in the middle of a long bendy section. It would be crazy to make the cut/weld where it would be visible when it is almost just as easy to make the cut/weld on the top which is hidden by it's heat-shield.I got my Elgrand 2 weeks ago and I had the rear cat removal done included in the cost (I blagged that haha) but it was only £180 to have done anyway that was with jay car finder in Bradford, the cut the inside of the cats out from the top and welded it back together so from underneath it still looks like the cat or is the cat but its just hollowed out and you cant see where anything has been tampered with so the mot tester would just think it is standard!
No aspect of de-catting causes an issue for sensors or the engine management system (no Mil light errors) provided the oxygen/lambda sensors are left in place. The question is whether or not a decatted Elgrand would pass an emissions test running on petrol. If all 4 cats are gutted it very likely will not pass an emissions test if it is running on petrol, although it will pass with all 4 cats gutted if it is running on LPG.Morning, would decating the front cats leaving the rears in place cause an issue for the sensors?
Most opt for 200 cell cats. As for brand-whatever floats your boat reallyHas anyone any recommendations for sports Cats for the front ?
Yes, a decore will mean no chance of a failed front cat, any type of replacement cat will be a new cat.So many questions, so few answers. Whatever you do it will be better than doing nothing.
Thanks for the info, I had cats de-cored.THIS IS NOT FORUM LORE. THIS IS NOT A MYTH. THERE HAVE BEEN MANY DOCUMENTED INCIDENTS WHERE OWNERS HAVE HAD THEIR ENGINE BLOW UP BECAUSE OF THIS ISSUE. YOU HAVE BEEN WARNED.
LIST OF AFFECTED MEMBERS
The problem
damage to the engine.
There are 3 main options.
3/ By far the most expensive option, but still an availability if you have the funds to allow it. Replace the WHOLE system (Manifold back) with a custom made stainless exhaust with single stage, high flow metal sports cat. Dig deep for this one, but the noise will be worth it - This option will 100% remove the risk of damage caused by the standard catalytic converter failure problem.
But what about.......?
Is this legal?
Why does this need doing?
Hi @Tana Here’s info why you should have rears Decored & the different methods .THIS IS NOT FORUM LORE. THIS IS NOT A MYTH. THERE HAVE BEEN MANY DOCUMENTED INCIDENTS WHERE OWNERS HAVE HAD THEIR ENGINE BLOW UP BECAUSE OF THIS ISSUE. YOU HAVE BEEN WARNED.
The problem
Is this legal?
