I brought cat replacement pipes and it took me an hour to do both.
Maybe that's the way to go?
I just thought them pipes were pretty pricey to get hold of on ebay for the sake of 100 quid or so to get them bashed out :D
Did you have much trouble getting the bolts off?
No trouble. Just a set of spanners and a bit of ACF 50.
I've done a lot of rear cat decores, they usually come off no problem but I've had to cut nuts off a few.
For £100 you could have a set of my refurbished factory de-cored rear cats delivered to your door, see my ad in the trade section.
Regards Adrian
Regards Adrian
Awesome.
Sounds like this is the best way to go, i'll have a look now.
@Winchester I've just sent you a private msg about this...
Hi guys, I'm having a nightmare trying to get the de-core done on my E51. I had it in with someone this morning and they did a no show and have messed me around to be honest for the last couple of weeks.
Is there anyone on here that comes out to do them that could be fairly local to me? Obviously will pay etc.
I'm close to Cannock and already have the 4 new Gaskets to replace the old ones with. I would have done it myself but don't really have the best gear to get the bolts off as they will probably need heating up to get off.
I don't mind travelling to someone either if they're fairly close?
Cheers,
Matt
Try Stuart Spencer Autos in Dudley Port ( Between Great Bridge andDudley roughly 35 mins from you),,they deal in Elgrands and they did mine no problems
Hi everyone, I've just been chatting to my father about getting his cats either de-cored or replaced, the question is, does anybody know of someone who can do this for him in the Middlesbrough area? Thanks.
Might be best to git up an exhaust shop and find out how much to do a front cat back system on the beast
LIST OF AFFECTED MEMBERS
The problem
damage to the engine.
There are 3 main options.
But what about.......?
Is this legal?
Why does this need doing?
Now I'm a bit nervous...not sure how I'm going to decide what to do about mine especially as I'm unlikely to be able to do this stuff myself. Will re-read and talk to the dealer....
Update: Dealer says option #1 or #2 is up time to choose but comes out around £330 for each.
Still trawling through the posts on this thread. Looks like it will pay me to shop around👍🏻
If you were to take advantage of the @Winchester postal exchange service it should take no longer than an hour for any competent mechanic to swap them out.
Hi all.
Can anyone tell me where I can get a stainless steel sports exhaust fitted to my E51, will this eliminate the cat problem, will I have any issues with the MOT regarding this mod? South Wales area.
Many thanks.
Hi all.
Many thanks.
depends on how much you want to spend. Avoid kwikfit and other national chains would be my advice. Like most things in life you pay peanuts - get monkeys.
For a decent one that replaces the exhaust from the manifold back - engine>manifold>pipe>sports cats>pipe>centre box>pipe>backbox>exhaust tips (fully purge welded and good sports cats) you'd be looking around £1500+ i reckon.
As for MOT, have a search on here. Several of us have had similar to what i mentioned above (me included) and no issues with MOT's etc
Thank you.
Hi all.
Many thanks.
There are a few clear options now.
For me - I chose front cat decore from Paul at Powerflow Cardiff (£240).
Plus LPG fitted by Simon @Lpgc
Now proven to be quite a good route.
