Just had my front cats done and no problems with engine light , I think they put spacers on so the sensors think they are working as normal. I run on lpg so have taken all the worry away regarding the car issues .😎👍
Be aware if the front cats are de-cored, you may have an issue with the engine check light. You'd be better off getting the fronts replaced with high performance after market cats that won't break down if you're going to the trouble.
Cheers
Hi, I'm in nz. First of all no emissions test re wof here. Second I'm interested in where you got it done. I don't mind spending 300 bucks to get the front cats decored!
300 bucks is cheap, I paid £175 for the de-cored pipes and £200 labour. One thing to bear in mind is, if they de-core the CATs whilst still on the vehicle, they'll need to remove the retaining ring with a metal gauze on it, otherwise it could cause a rattle later on.
Regarding the EML light, if it comes on that can be dealt with universal spacers found on Amazon for around £10 a pair.
These should do... https://www.amazon.co.uk/gp/product/B07R32H6RK/ref=ppx_yo_dt_b_asin_title_o02_s00?ie=UTF8&psc=1
The engine warning light doesn't come on if front and/or rear cats are decored.
Under no circumstances should you fit spacers on front lambda probes... It isn't necessary, the engine light won't come on anyway, in fact fitting spacers on front probes is probably more likely to turn on the engine light. Fitting spacers on front probes will be detrimental to accuracy of fuelling.
On other make/model vehicles that have had cats decored spacers are sometimes fitted on rear probes to prevent the engine warning light coming on, never on front probes. Fitting spacers on rear probes can prevent the ECU detecting that the cats are not working (they wouldn't be working when they've been removed!).
Fitting spacers has the effect of slowing the signal response of sensors and making them read a leaner than actual mixture - maybe a good thing on rear probes because rear probes are really only there to check that cats are working properly, but never a good thing on front probes because front probes are there to steer the ECU to provide correct mixture for the engine. Fitting spacers on rear probes on Elgrands seem unnecessary because the ECU doesn't seem to generate errors for missing cats anyway, in which case the only reason for rear probes on Elgrands is to nod to the standards (which says rear probes have to be fitted to check cats are working).. never mind if the cat checking doesn't really work/function as the standards intended!
Just leaving this here.
In case you want your front cats decored at a fair price:-
Powerflow Cardiff
Cardiff Remap Ltd.
West Point Industrial Estate
Penarth Road
Llandough
Cardiff
CF118JQ
02921328023
cardiff@powerflowexhausts.co.uk
Ask for Paul.
Tell him Steve sent you.
And if you're happy with the price put a pound in a charity box on my behalf.
They do well to manage decoring front cats, there isn't enough space to swing a cat around in the areas where work needs to be done. Probably safe to say that here, won't be many cat lovers on this forum.
One guy on a facebook Elgrand forum reckons he can change out the front cats in 2 hours, and it's easily done?
Truth or bollocks?
Truth or bollocks?
Absolutely no idea at all.
But what price experience eh?
Good luck to the man if he can.
Truth or bollocks?
Maybe if he's super quick at dropping the lump down... otherwise even Steve from TojoMotors wants the van for the day to do the job.
I had mine done from a local known mechanic, reckoned he'd get it done in half a day but instead took all day.
From all accounts everywhere, that's what I've heard. About a day. If bolts are snapped, make it 2.
The issue is removing the heat shields around the CATs, on the nearside a few water pipes need removing to gain access to the one nut n bolt from the engine bay, the other two nuts can be accessed from underneath using long extensions. The heat shields need to bent around slightly in order to come out and once they're out it should be plane sailing thereafter...
If the EML light flags up after that you might need universal O2 sensor spacers found on amazon for £10, if it doesn't then enjoy the peace of mind knowing that the main culprits are out. ;)
Truth or bollocks?
Don't know. Might also depend on what exactly they mean... E.g. have they done preliminary work such as removing other parts for access before they start the clock? Swap out for another pipe or does the time include decating the original exhaust they removed? Guestimate of best case scenario or average time in their experience?
It took me longer than 2 hours just to decat the fronts when I'd already removed them from the car.. but I cut the heat shields off, cut the cats to decore them, had to reweld the cats then weld the heat shields back on.
Would be interested to see the Facebook comments, can you post a link?
Truth or bollocks?
Brute force and ignorance? Gorilla with an angle grinder?
There are many car maintenance tasks that can be done quickly. Its whether you want them done on a car you care about.
Based on the experience of Steve at Tojo, Powerflow and Infinity exhausts as well as others I'd be cautious of that claim. Even decoring them up on a 4 post lift takes longer than that (Need to take care with the bits).
So either he is confusing it with the rears or his engine bay now resembles Princess Di's last motor.
Bollocks,
Took 2 experienced exhaust blokes 6 hours to strip the exhaust off our e51....
2.5 hours to build and fit the stainless steel replacement 👍
(No cats in new exhaust)😎
Just got rid of my secondary cats, with stainless pipes, immediately feels better reving, with the added bonus of not worrying if the engine will blow
H
Bollocks,
How much and where from
LIST OF AFFECTED MEMBERS
The problem
damage to the engine.
There are 3 main options.
But what about.......?
Is this legal?
Why does this need doing?
Im using straight through pipes I managed to source from Australia
