Awesome... thanks mate... I'll drop them a line. Do I need to get google to translate it to Japanese do you think?
probably worth doing both as i'm not sure how offensive google translate is with english > japanese :joy:
:joy::joy::joy: I think I better just stick with English. The last think I want to do is risk google messing up the translation!
I'll also let you guys know what happened with the dealer tomorrow. Nite nite from down under.
OK an update...
Got a reply email from Japan, and asked me to forward email to Nissan Australia. Contacted my local dealer, had a chat, forwarded the email, now wait. Hopefully they will do these 2 recall items for me.
After reading all of these (well some of all of these posts) I'm a bit concerned. I have a 2005 E51 Rider Autech 2.5 v6. Checked the recall site and it only has 1 recall for 2006, no idea what it was for lol but it's marked as done :). Does this mean I'm free of the CAT issues? Possibly relevant... my van has clocked up 180k km!
*going to have to read up on how to insert images smh
Hi everyone
So I'm in a very upset state right now and pretty stressed. I brought my E51 to a mechanic in NZ today and explained very precisely that I wanted to take out the 2 rear catalytic converters, explaining what we all already know about the car being a quad cat and front breaking up blablabla
I came back and I realized they didn't do the rear cats but did front cats, they cut open the pipes, broke down the honeycomb, soldered everything back on, leaving the compression ring inside. The boss thought I was a morron and was sure the rear cats were just small resonators or something so decided to do the front thinking they were the only one. I had to ask him after the mistake was done to check the rear ones for him to realized he fucked up, but still never apologized.
I showed them I was pretty unhappy, I still had to pay 300NZD, thinking anyway decorinng the front cats was still a good thing as it's the source of the problem
Then I realized there was a rattle in the line, which seemed like the compression rings moving around (he assured me there was no honeycomb left at all but that they put the compression ring back in place). So the guy told me to come back tomorrow and they'll cut the rings and take them out, I'll tell them to make sure there is no honeycomb anymore in the line.
But now beside being worried they left some materials in there or that they fucked up something, I'm also worried that the car will fail emission tests (I'm in NZ and no idea how they do that)
Engine light didn't come off after driving for a bit, so that's one thing I'm a bit less worried about ...
Do you think emissions tests will be OK ?
Should I ask him to put some new front cats for free after he did the mistake ? Thing is, I'm afraid he's just gonna tell me to f*** off and I don't have time and money for this.
I almost regret getting into this ... :(
In the UK rear cats only will pass emissions, but it depends on the rules in NZ. If they are more strict then I couldn't be sure.
You could ask him to provide you with an emissions test to be sure its OK and if not you'll be in a better position to get them to sort it out now rather than trying to go back later.
LIST OF AFFECTED MEMBERS
The problem
damage to the engine.
There are 3 main options.
But what about.......?
Is this legal?
Why does this need doing?
The problem
Is this legal?
The problem
Is this legal?
Good honest advice
The story continues, so the guy cut the pipes again this morning to take out the metal rings which were rattling, and also told me he started decoring the rear cats aswel thinking he was doing me a favour. Wtf is wrong with people ..... He didn't even ask before
I asked him about emission tests (and double checked myself) there is no emission test being performed during MOT in NZ (yet!), only during initial inspection at registration of the vehicle. But I'm still fucking upset
So I'm left with only one cat now as I stopped him before he started decoring the second one, I hope it's going to be all good. Will it create any problem if the 2 exhaust lines are not "balanced" ?
I would say, if emissions aren't a problem the ditch the last cat also so you will then have a full free flowing exhaust.
Doubt there'll be anything to notice due to inbalance.
You won't get an engine warning light on due to decats.
Agreed
No i don't think it'll cause any problems only having one in one side. Though I get where you're coming from about it been imbalanced.
You're kind of left with option of finding a second hand rear cat to replace the one he started on. (Fairly straightforward job to replace if you can find one) or replace both rears with some aftermarket cats. But probably looking at a few hundred dollars to have them put in. Or just finish taking the last one out and leave with none if emissions aren't a problem over there
Well I already told him to let the last one so...
Another update...
Looks like a local dealer is giving me the run around.
In the ned they tell me they can do the recalls because to quote:
"they can't connect their computers to foreign cars".
I called them on their BS and went in face to face, then they started telling me they needed authorsiation from Nissan Japan.
I showed them the email from Japan, and the dude said he would take it up with Nissan Australia again. I wait again.
He tried to tell me Nissan Australia said they never do recall work on imports. He went silent when I told him others have had it done.
I'm smelling some bullshit here.... maybe it's just this dealer.
Sounds like they just don't want to do it.
To be honest, I don't think I want them to do it now either. I may go to another dealer. I don't want them to do it begrudgingly.
I have had this problem twice since august. The engine warning light appears in screen and the engine symbol on the dash board lights up. It is followed within 30mins ish by brief intermittent engine stuttering. This first happened abroad in august. A local Nissan dealer in Switzerland cleared the warning and said it was probably electronic. After returning to UK i got my local mechanic to check it but he said as warning had been cleared the diagnostic check didn't reveal anything. I have done 2000 miles since with no problems. On long journey to Scotland over Xmas the problem returned. However i managed to return to Essex without the car showing any further symptoms. Is this the start of Catalytic problems or is it something else? I have been putting various types of petrol in the car from E95 to E99 (depending on availability).
I had a similar issue with mine turned out to be the PCV valve
Hi everyone
Hi, I'm in nz. First of all no emissions test re wof here. Second I'm interested in where you got it done. I don't mind spending 300 bucks to get the front cats decored!
Be aware if the front cats are de-cored, you may have an issue with the engine check light. You'd be better off getting the fronts replaced with high performance after market cats that won't break down if you're going to the trouble.
