Is it the grey E50?
White e51 I believe. Theres also no mention on it being under sealed. That would need addressing
Hi Guys thanks for letting me join, please could i ask does any one know of a garage near sheffield or surrounding areas that could decore the cats for me? I have bought a 2004 Highway star, and after reading lots of here and online im anxious to get the cats done:( also im due a long journey in a weeks time, am i best getting this done before i go? Many thanks xxx
Sooner is always better than later. PM @Winchester he does an exchange on de cored cats.
@stevemen is in Yorkshire. Not sure if he decores cats but it's worth asking if he does can he fit you in before your long trip.
www.elgrandcarparts.co.uk/
Many thanks for the info i will get intouch!! Can i just confirm its to 'decore the cats' and this way it is more likely that it will pass its MOT next time round as the cat will still be there sheilded, but just blocked up? Is that right? Also do i need all 4 done or just back 2?
Many thanks! Im sure by now you can tell im all new at this!😂
To decore the rear cats means they open up the cats and scrape out all the catalytic materials and then weld it back up so you can't tell. It doesn't make it more likely to pass an mot. It means that it is less likely that the front cats will block the exhaust should they disintegrate. Therefore less likely to knackered your engine.
You can also replace the rear cats with a straight through pipe but that's a slightly more expensive option.
As @Hoobajoob says decore or replace rear cats, with decore being the best option if you trust the mechanic to do the job.
Hopefully @stevemen does them or can recommend someone near to you. Let us know how you get on @Lucypink1 :)
Am I right in saying that both procedures are potential MOT failures?
Technically yes under the new rules but having the rear cats removed won't make you fail on emissions
If they are decored there would be no way for an MOT inspector to know they'd been done.
Gotcha. I was having a chat with my mechanic on Friday. We discussed the cat issue (which I’m still yet to sort). He mentioned the MOT failure, but then I guess he would if he did the job and then MOT’d it next year. His verdict was to leave things as they are because the van is driving as sweet as a nut and that I’d get warning signs should one of the cats go. I’m not saying he’s right and I’m heeding all the opinions in this thread.
By the time you get a warning sign the damage is done mate. Get them done, even if you don't want to use your regular MOT guy. You need them sorting I can probably give you a number of someone in port Talbot who will do it in an hour if that's any use.
Thanks, Chris. The dealer I bought the car off said he’d do it for £80, so I have options. Many thanks again.
For £80 he's no doubt doing half a job mate.
Needs to check condition of front cats also. If deteriorated needs to remove or replace them (if removing them need rear cats left in , but must be unblocked and clear). Also need to removed debris from rest of exhaust.
I've mentioned it a number of times floating lumps of broken cat in the exhaust can cause swirling and the dust gets drawn back in the swirl gradually wearing away at the engine.
Best getting it done right that take the risk. We've had to replace quite a few engines that have suffered with this problem even with back cats removed.
Steve Tojomotorsuk
