Power/Snow Mode
The Boss
North East
Hartlepool
E-Bucks
6870
E50
North East
If there is no big dial on the right hand side of the dash that selects between 2WD/4WD/Auto then you do not have a 4WD. The controls are pretty obvious and directly in the drivers line of sight. They are NOT near the snow/power mode buttons.
Also as above, your chassis code will tell you if it's 4WD
E51 (3.5)/ME51 (2.5) are 2WD
NE51 (3.5)/NME51 (2.5) are 4WD
geordie001
Midlands
worcesrer
E-Bucks
28
Peter
Midlands
had my Elgrand broken into in Oct 2018 just been informed I am getting it back on Monday second phone call to say a button was missing and do I know what it was I contacted the place I purchased it from and was informed it was the power snow button anyone got any idea where I ca purchase a replacement help appreciated
thanks
stevemen
Yorkshire
beverley, east yorkshire
E-Bucks
735
steve
Yorkshire
thanks
Got plenty of them
Steve
Tojomotorsuk
Stempyuno
South East
Down The Dustpipe
E-Bucks
5009
Andrew
South East
drbikramjitsingh
Ludhiana
E-Bucks
5
Bikramjit
Looking to buy
I'm not sure about how it affects the petrol E50/E51, but on my derv E50 it gets better mpg around the houses in power mode
The Boss
North East
Hartlepool
E-Bucks
6870
E50
North East
This is because in the old 3.2 if you put it into power mode, you keep the rev range in the turbo power band, meaning the turbo works harder rather than the engine, which saves fuel. I do not think this is the case on any other engine type, although claims have been made.
Andy700
Devon/Cornwall
Devon
E-Bucks
985
Andy
Devon/Conrwall
I may be wrong, but I'm pretty sure on my E51, it doesn't just change the gear change rpm thresholds but also the throttle response. In SNOW mode the throttle response is very gradual whereas in POWER it seems like it's direct. In my wife's Juke these are SPORT, NORMAL and ECO. As accelerator pedals are all electric these days, my understanding is the ECO mode reduces throttle responsiveness so as not to waste fuel when pressing the accelerator. You put your foot down but the engine is instructed to increase the throttle at a much slower rate as the speed and rpm increase. Plus, in ECO mode it effectively reduces throttle amounts so at 50% pedal push it might only translate to 35% throttle, whereas SPORT mode would demand full 50%, if that makes sense. I find SNOW operates very much the same as her ECO mode, but with the added interaction of the automatic gearbox as well.
Anyway long story short, SNOW mode returns much better mpg for me, as does 36psi instead of 32.
djaolnes2
Sydney
E-Bucks
76
Dale
Yes, it changes the throttle response as well. Its obvious if you have a Pivot 3 throttle controller. If you put it into the sport mode, it exaggerates the throttle control. If you then switch the Elgrand into Snow mode it then gives slow/subtle throttle changes despite what the Pivot3 is sending out.
Stempyuno
South East
Down The Dustpipe
E-Bucks
5009
Andrew
South East
I have found this also with my Pivot.
Lizard M
Yorkshire
North Lincolnshire
E-Bucks
14
Liz
Looking to buy
Yorkshire
How do you know if you are in power or normal? Does it show up on the screen? I pressed mine yesterday and it didn't seem to do anything but i have only had my E51 since Saturday
Mystique
Midlands
Birmingham
E-Bucks
0
Brian
Midlands
Nice that you got one , it should light up either power or snow on the side of the clocks , mine lights up on the right side of the rev counter .
ColytonJohn
Devon/Cornwall
Paignton, Devon
E-Bucks
259
John
Devon/Conrwall
I haven't driven my S2 E51 much yet (so I may get used to this in time) but what was obvious from the outset is just how sharp the throttle is off tickover; slightest depression of the pedal and it leaps forward. Not a problem on the open road but it certainly focuses the mind in traffic. I was wondering, then, if there would be benefit in (or reason for not) selecting 'snow' for town driving. Any thoughts?
