- Skelmersdale
- paul
- North West
I think it's loads better
Bish bosch.work perfectCLUB.
I need your assistance.
Following a few recommendations on here I brought some Michelin Stealth Hybrid wiper blades on line.
They fit and they work well.
But they look shit.
See photos of my old Bosch vis the new Michelins.
I'm currently in discussion with the guys at Michelin about this.
They are saying that the OEM was Denso and that Denso did not have a (nice looking) cover like the Bosch.
Can ya all take a look/photo/post of what you have with the suppliers name please?
This is club stuff!!
I'd love to get a result.
Nothing to do with the £20 cost.
I want a nicely designed finish without stress.
Can you lot help please??
Just bought Michelins but these look so much better. Might need to swap.If it helps, I fitted the Denso hybrids a couple of Fridays back. They look alright and perform well (no lifting).
Got them through euro car parts. With the discounts came out at 21 quid for the pair. Tip, don't enter model details as their database doesn't cover wiper blades for the Elgrand apart from the rear. Blades are working well, tested on the m62 over a weekend and believe me the weather was shi...
Part numbers are.
26 inch 485778266
16 inch 485778166
Fitted aerotwins, driver's wouldn't clear the middle of the arc. Very disappointing as they've been my go to wiper for years but others have reported similar issues so swapped to the Michelins.I put some Michelin wiper blade so on my friend car at the weekend … they look like something outta the arc.. have Bosch aero twins on all our cars they look much better and work great
How did you find the Michelins?Fitted aerotwins, driver's wouldn't clear the middle of the arc. Very disappointing as they've been my go to wiper for years but others have reported similar issues so swapped to the Michelins.
Was very happy with them.How did you find the Michelins?
I've just tried the aerotwins and had the same issue, sent the first one back thinking it was defective, but nope, second exactly the same.
Yes, this is what I'm getting with the BOSCH aerotwins.Fitted aerotwins, driver's wouldn't clear the middle of the arc. Very disappointing as they've been my go to wiper for years but others have reported similar issues so swapped to the Michelins.
Hope this happens with mineFor what it’s worth, when I bought the car, dealer had fitted the Bosch and indeed, they left a puddle in the centre. However, they bedded in and after a couple of months work perfectly. I think I inadvertently pulled them off the glass to clean and allowed them to slap back, if that helped I can’t say but it may be worth saving your £ and see if they get better With normal use.
Would that issue you had with the one's you thought were BOSCH had been an MOT fail, maybe due to 'not clearing the windscreen effectively', or have they got to do a far worse job of clearing to fail on that?Actually, I recently found they they weren’t Bosch, they were a cheap blade off eBay. I have since bought some more (dealer gave me the link) and they don’t leave a smear but they do make a click noise as they change direction. They look nicer than generic blades so I keep em on.
Patch that didn’t clear properly was about the size of a swan vestas pack but didn’t fail MOT as by Then they had settled in. Also, I pulled it away from screen and let it slap a few times which helped. I’m now on my second set of cheapies and they don’t smear at all, just click on direction change.Would that issue you had with the one's you thought were BOSCH had been an MOT fail, maybe due to 'not clearing the windscreen effectively', or have they got to do a far worse job of clearing to fail on that?
Now sorted. Just standard bosch wipers. Shame as I like the aero design. But at least I can see.So as I'm having the same issue, let them slap onto the screen a few times to help bed them in. That's bloody ridiculous. I paid £25 for something that doesn't work right from the get go! Will try it but very disappointed in bosch. My last set on my first series 3 were brilliant. Still going fine 4 years later! Back blade I bought separately is going back as doesn't even fit! Bosch again!
Do you mean the standard 'cage-like' Bosch wipers are fine, but the aeros are naff (which is what I found with the aeros and took them back)?Now sorted. Just standard bosch wipers. Shame as I like the aero design. But at least I can see.
Yep. They must have changed design slightly as 4 years ago I bought a set of aeros and they were great. Lasted 4 years and looked good.Do you mean the standard 'cage-like' Bosch wipers are fine, but the aeros are naff (which is what I found with the aeros and took them back)?
