- Greater Manchester
- Danny
- North West
Looking for some advice and recommendations please.
I bought my Elgrand E51 Series 3 from a well-regarded member on here. A few months in, the alternator failed — the seller agreed to repair it under warranty, which I really appreciated. He also mentioned he replaced the power steering pump at the same time because he could hear it starting to fail — again, great service I thought.
A couple of months later I noticed the power steering fluid had dropped. I topped it up with fresh fluid including an additive to help seal any minor leaks. Fast forward to now — the (new) alternator has failed again.
I took it to a local garage who said it looks like the replacement power steering pump was fitted using the original fittings/pipework and may have been leaking onto the alternator. He didn’t want to take the job on and basically told me to drive it straight back to the seller and insist they put it right, as their previous work hasn’t actually resolved the issue.
I can see both sides — the seller did honour the warranty and carry out the repair, but if it’s been fitted incorrectly and caused the alternator to fail again, where do I stand?
The dealer is saying it’s just the pipes leaking and nothing to do with his work.
So I’m asking for some outside opinions — what would you do in this situation? And can anyone recommend a trustworthy Elgrand/auto specialist near the Rochdale area?
Photo of leak
Thanks in advance.
Photo of leak
Thanks in advance.
