Code Reading
Some of the site wont work as you need to post 10 or more to activate the whole forum
hi guys does anyone know where the water temp sensor is located???
If you mean the engine's coolant temp sensor it is at the rear of the engine at the passenger side just behind the passenger side cam cover. It sticks up from the water elbow on the engine, it is high up on the engine and close to the transmission tunnel.
Perfect. Do you know the best way to it, my mechanic is saying he needs to drop the engine a bit to even get to it?!
And thanks!
it's all covered in the link earlier in this thread. Quick answer is yes but no, the link will explain everything.
Bit frustrated to be locked out from that part of the forum
Firstly its OBDC as in on board diagnostic connector and the answer is NO & YES respectively
Neither the E50 or E51 are OBDII compliant. The E51 has the same connector as used by vehicles that are compliant though but uses a communications protocol called Nissan Consult 2.
As recommended by @spuddyo , follow the link to get further info.
this link doesn't work for me either
1 month premium membership can be purchased for only £3
All posts count.
Evening folks, excuse me thread hijacking, and apologies if this is explained in the "10 posts +" locked threads, but is there a way of making a normal OBD Reader communicate with an E51?
Back story: I've got the minor engine light come up on my dash and won't get to a garage before I get home on Wednesday night (Bank holiday + holiday activities + drive home). I have a bog standard OBD Reader at home, and I'm hoping to figure out what the issue is then, but read earlier in this thread that the communication protocol is different for the E51.
Any help is appreciated as I'm away until next Wednesday and won't have the opportunity to post ten times before that.
Thanks folks!
Edit; I reckon it's probably MAF-related as the van's running fine, but we shall see. It only came up this afternoon, so I'll have to see how it progresses over the weekend.
Also there's no garages or mechanics in the area open this side of Tuesday morning, hence not just getting it checked there.
