- Surrey
- Ian
- South East
Hi Sam,Thankyou ill let you know how it goes.
Did you ever find out what the problem with your boot was?
Hi, we have a bag strap stuck in the boot and trying to do this. Not sure if we have the right panel, Could you do a picture? ThanksThere is a flap at the bottom on the inside that has a handle behind it. This is the emergency release.
This will open it so you can investigate it further.
May have something caught in the latch.
the problem was I needed another lock boot lock
Its at the bottom leftish of the boot panel , remove the small panel its about 6in square then you can get at the boot release handle.Hi, we have a bag strap stuck in the boot and trying to do this. Not sure if we have the right panel, Could you do a picture? Thanks
Found a lever but It doesn’t seem to open it, push/pull/lift etc. Any ideas?Its at the bottom leftish of the boot panel , remove the small panel its about 6in square then you can get at the boot release handle.
Is #3 for the boot as I have the same problem.I think the fuse box is behind the passenger side rear panel
Is it right at he back below the window? Does the curtain rail come with it?Put your fingers between glass and top of panel and give a good tug , the side panel is in 2 parts and the top fabric bit will come away from the bottom bit of the panel . Then you can get to the fuse box
I assume you need to undo the bottom bit of the curtain from the rail.Is it right at he back below the window? Does the curtain rail come with it?
Hi Lee,Where do I find this panel? Do I pull the material lining off? I can open the boot by the handle but no soft close or open on electric button?
