Back on the road.
Hoobajoob
North East
Billingham
Steve
Ex Owner
North East
So I've been without transport since back in February when my water pump let go.( not an Elgrand obviously had I still had my Elgrand the water pump wouldn't have broken) I saved up and got all the parts I needed and fixed and serviced it at the same time. Then my mot ran out before the extension cut off. So put it in for an mot and failed on bushing and the fact the rear brakes did nothing. So, saved up again and did my lower control arm bushings. I should add that everything had seized with rust making it a pig of a job. I had to cut the camber bolt sub assembly with a reciprocating saw. I ordered parts for the rear brakes from all over the world as the lockdown closed all the places i could have got them in england. Drop link bushings turned out to be past it as well so I upgraded the drop links and changed the bushings. Then I had to do the tie rod ends as they had become 1 with years of rust and I would clearly need my alignment doing and I could just see the guy at the garage sucking his teeth saying they're not gonna budge. Even had to change an inner tie rod. So I had to save up for those as well. Once all that was done I finally could take it off the axle stands and get the rear brakes rebuilt.
Before this I wasn't really one for doing mechanical work on my own cars. I once changed the oil of an audi about 20 years ago. I took my time and found guides on the jobs I needed to do. I had to get creative a few times cause of rusted components. Never the less I got it all done and today I took it for an alignment and an mot. I'm told the alignment wasn't that far out which makes me happy as I set them by eye alone and i now have a years MOT woohoo. The 24 year old zombie survival prepper red neck mobile lives again. I'm quite proud of my achievement. Wish I still had my Elgrand though. Haha.
Hoobajoob
North East
Billingham
Steve
Ex Owner
North East
Great work, especially for a novice with the spanners. Engine rebuild next.
That is a possibility to be honest. I'll have to see how it goes over the next few months. Fingers crossed it doesnt need it but it did over heat and there is the potential of a cracked head. If that is the case then I'm extremely tempted to stick a v8 out of an old lexus in it instead.
Elliematt83
Yorkshire
Hull
Matthew
E50
Yorkshire
Sounds like you had your work cut out good you got the zombie bus back on the road incase of an apocalypse :cool:
Hoobajoob
North East
Billingham
Steve
Ex Owner
North East
Well of course. Next its clearly time for extended breathers then I should also be ok if a volcano erupts and I need to cross a river. Haha.
Also if any north east members need any bushings changed I have a useful tool for removing them and pressing them back in again.
I dare say with an Elgrand you dont need to remove the steering rack first to get at the bolts.
Gezza
Wales
Wales
Gerry
Wales
Good on yer pal, more patience than me.πŸ‘
The Boss
North East
Billingham
E50
North East
Was wondering why it was on axle stands when we drove past to Tesco. And now I know.
Sorry you've had a chew on, but great sense of pride knowing you've fixed it yourself. Well done bud!
Hoobajoob
North East
Billingham
Steve
Ex Owner
North East
Why thank you. 😁. The neighbor's will all be fed up now as they cant park in front on my driveway anymore. I dont mind if they do as I can always just drive over them πŸ˜†πŸ€£
