A novices guide to Elgrand acquisition
jclarkson
Yorkshire
Halifax
John
Looking to buy
Yorkshire
Great Advice. I' starting my journey to find the right Elgrand. Some top tips here :)
Same question - what ebay dealer did you use?
Mellowyellow
Scotland
Paisley
Sam
Scotland
Here’s my Elgrand buying experience in case it helps anyone else in the buying process.
After deciding that I really wanted an Elgrand, I found a dealer quite near to me. I had already decided I didn’t want to spend time and expense trawling up and down the country looking for my new car, so some internet research led me to the more local options.
Being a novice in the import vehicle field I also decided that I was willing to pay a bit more for someone else to deal with procedures involved in bringing a car in from Japan rather than trying to do it myself. I could also be sure to see the vehicle before making my purchase.
I found a likely candidate at my nearest dealer who were advertising it as low mileage and top quality on their website and ebay. The vehicle in question had not yet landed from Japan, it was a silver Rider model but sounded from the description that it would be just what I wanted.
I visited the dealer and left a deposit on the strength of their pictures, advertisement and description. Then, whist awaiting its arrival I thought it might be a good idea to do some further research online and signed up to this club to seek advice and information about my impending purchase. Good move.
After much reading and advice from those more experienced in Elgrandery, I discovered the many ways of checking how closely the dealers spiel matched reality. As it happens I saved myself a wait for a vehicle that wasn’t all it was cracked up to be. It turns out that the dealer in question are importing low grade auction vehicles then tarting them up on arrival. Happily, they refunded my deposit without quibble when I approached them with the discrepancies I had found.
Here’s what I checked using the vehicles chassis number.
Firstly, they claimed the the vehicle had Jevic mileage certification. I checked the chassis number on the Jevic website https://www.jevic.co.uk/index.html but it returned no results. Warning bells started to ring.
I next paid for a CarVX report at https://carvx.jp/ costing £25 plus £3.50 for the translation of the Japanese auction sheet. The report showed that this vehicle was a low grade auction rating, had been repaired following accident damage and had a replacement door panel which was an incorrect shade of silver. It was rusty underneath, dirty, smelly and marked inside and full of pet hair, and had numerous dings to the bodywork amongst other horrors.
On the plus side, the recall history was complete which can be checked here http://www.Nissan.co.jp/RECALL/search.html and this shows that important recall work has been carried out, most importantly correction to the over fuelling problem which adds to the premature disintegration of the catalytic converters, and also the dodgy fuel gauge issue. But even so, this seemed to be a poorly maintained vehicle and certainly best avoided I thought, and I note it has been removed from sale by the dealer.
Finally, I also checked https://Nissan.epc-data.com/Elgrand/ which shows up some basic info on specification, but doesn’t show any spec for vehicles which finished production at Autech such as Rider models.
Further searches found two more likely vehicles. The first I checked was a white Rider but it had not had the over fuelling recall carried out and although it showed a full Japanese service history it didn’t have Jevic mileage certification either, so I passed. It had also been pimped somewhat in Japan and I was looking for something that had not been too interfered with.
Third time lucky I found a gem from an ebay trader and Japanese import specialist in Kent. A low mileage 4x4 twin sun roof white Rider with verified Jevic mileage certificate, full service history and 4.5 auction grade shown on the CarVX report with no issues reported on the auction sheet. All recalls have been carried out and on inspection I found it had been very well looked after by its Japanese owner, modifications being to the side and mirror repeater indicators, a remapped ECU and a throttle control unit.
It is quite hard to believe that this is a 15 year old vehicle, with only 44k miles it looks only two or three years old and is in super condition. As you can tell I am delighted, as without this splendid club I could well have ended up with a lemon.
Just as an addendum, when you have acquired your piece of masterful engineering you MUST have the secondary catalytic converters de-cored or fit bypass pipes or your lovely new Elgrand WILL die prematurely. It's also a very good idea to have them undersealed as JDM vehicles are bare underneath, so factor the cost of these things into the cost of the purchase or risk an unnecessarily short ownership or huge expense down the line.
Hi there,
you mentioned factoring in the decore or bypassed. would you recommend taking this to a garage to have done? how much roughly will it cost?
Stempyuno
Part of the furniture
South East
Down The Dustpipe
Andrew
South East
Hi there,
If you are handy with a spanner bypass pipes will take an hour or two to fit as long as you can safely jack the vehicle for access below. You are looking at around £220 for parts from ebay or you could maybe find a local exhaust shop that could make them up cheaper. Decoring is best left to someone with welding gear as the longer one will need cutting open. There are several members on here who can do the job from around £150. Do a search to find your best option. The cores are made of nasty stuff so best left to an expert.
Michael6457
Midlands
Birmingham
michael
Midlands
great write up I have saved the data and recall links to my favourites bar, but when I used the recall link it came back with no data found maybe an e-mail to Nissan to check is the way forward but I do have the service book with the car with lots of stamps in it
Stempyuno
South East
Down The Dustpipe
Andrew
South East
You have to be quite precise in how you fill the two data fields for the chassis number.
Dane Cauffeur
North East
Northumberland
Ian
North East
It is a really good check list for buying an import. The thing that makes me smile is the general comment about imports is the risk of unknown history. The reality is with the JDM system of buying/selling/repairing with the above list you know more about a car 5000 miles away than the one at the bottom of your street. One other point to add is our dealer invited us to be present when the car arrives from the docks and they take delivery. At that point we have an opportunity to say if we are happy or not. If you are a hoarder you will probably enjoy the process. I was at the dealer when three Elgrands where delivered and opened for the first time. They had spare winter wheels/tyres, modified grills ect had originals inside, they all had absolutely huge base units ect. Lots of extras to hang in the garage and bang your head on for the next ten years!
Dudejlh
North West
UK
Jake
North West
Very useful as I'm mid-purchase right now. THANKS!
Scalv16
North East
Teesside
Stephen
North East
Nice one - very useful indeed. One point - quite a few members (me included) have had the overfuelling recall carried out here in the UK - it's a very simple process - so potential buyers shouldn't be put off by that.
Hi, I have just checked online and it comes up that mine hasent been done if I just call mg local Nissan garage will they sort it?
Stempyuno
South East
Down The Dustpipe
Andrew
South East
Nissan UK have been known to honour some of the JDM recalls so definately worth asking. Perhaps an email to Japan might help too.
Scalv16
North East
Teesside
Stephen
North East
Fingers crossed knowing my luck they won't!!
Snow
Midlands
Kenilworth
Andy
Looking to buy
Midlands
Really useful read ta
Little Pete34
South East
Hampshire
Peter
Looking to buy
South East
Thank you for the tips. My first imported car that was not from a friend of a friend so good to get the info
