E51 Will 16" Alloys fit ??
micky_h
Hi all
Rather than go with massive rims with skinny tyres, risking buckling the rims or having a bad ride,
does anyone know if 16" alloys will fit??
i fancy something like these <!-- m --><a class="postlink" href="http://www.rimluxe.co.uk/ProductDetails.asp?ProductCode=ST5-GOLD">http://www.rimluxe.co.uk/ProductDetails ... e=ST5-GOLD</a><!-- m -->
cheers
mike
Rapperfrapper
Administrator
#2
In a nut shell, yes 16 wheels will fit as well as 17 and 18 but as you didn't want low profile tyres you'll not be interested in these other sizes, to keep the rolling circumference the same as standard tyres and to make your speedo accurate we've created a chart to show you all the wheel and tyre size combinations that will keep your speedo correct, see this link
<!-- m --><a class="postlink" href="https://forum.elgrandoc.uk/viewtopic.php?f=61&t=222&sid=991e13a1f6d2691f21b1fd8d437d8118">https://forum.elgrandoc.uk/viewtopic.ph ... 8d437d8118</a><!-- m -->
Rapperfrapper
Administrator
#3
Just took a look at the wheels you posted a link to and they look nice, just make sure they can make them with correct stud pattern and offset and correct size to fit the hubs, plus ask if they will take the weight of an Elgrand as it's nearly 2 tons, if they tick all those boxes than I'd say go for them, just use the guide to get correct size tyres.
Rapper, micky has an E51 so the tyre size chart won't be relevant as that's for an E50. We should make one for the E51 if we can get the standard tyre size.
Not sure what the standard size wheel is on an E51, I think it's 16". You need to be careful to ensure they will fit over the front calipers. I an almost certain that stock wheels on certain models are 16". So you should be fine.
028
#5
love the style!Im a big fan of deep dish 2piece small diameter wide rims.had a few different classic japanese old school ones on my 280z a few years back.
for tyre size,google miata tyre,that site will calculate difference between your tyre and the tyre.you are.buying.
tare mass for my e51 is 2010kg from my compliance report
micky_h
just found a FB post where a E51 owner has 16" alloys on, so guess they fit ok
<!-- m --><a class="postlink" href="https://www.facebook.com/photo.php?fbid=670760433051935&set=gm.960628493970552&type=1&theater">https://www.facebook.com/photo.php?fbid ... =1&theater</a><!-- m -->
mike
#8
What's the standard size of E51 wheels? Are the standard ones 17"?
micky_h
omg, wish id looked 1st , the standard alloys are 16" could have sworn they were 17"
well it was dark when i posted,
note to self, go outside and look b4 posting lol
mike
JonRWB
The 420 refers to the maximum pressure for the compact spare wheel (Type T155/70D17) - 4.2 bar = 60 PSI = 420 kiloPascals (kPa)
Highway Star - 17"
All others afaik - 16"
Except Rider - 18"
Standard e51 16" door sticker
Elgrand E51 tyre size & pressure sticker by -BitchinRob ( <!-- m --><a class="postlink" href="http://MrRob.in">http://MrRob.in</a><!-- m --> )-
I run my 18" summer tyres (235/50 r18) at 34psi for more comfortable ride.
More tyre / wheel info here <!-- m --><a class="postlink" href="http://bitchinvan.tumblr.com/post/32751241695/e51-alloy-wheels-up-grade-sizes">http://bitchinvan.tumblr.com/post/32751 ... rade-sizes</a><!-- m -->
