E51 Where can I hide my Amp(s)?
Chimestrike
Hi All,
I'm looking to sort the audio in the bus and have been thinking about where I can put my amps where they will be hidden away, question is where?
Has anyone had any success with putting them in behind the rear quarter panels or is there a nice space where they can be tucked away (too big for the foot steps holes)
The sub amp I was going to build into the amp box so it can be removed if needed when I go to shift stuff but I'm struggling for ideas and with the weather I don't want to really pull random panels off in the cold and risk braking things if someone knows of some good spots
Cheers in advance
Madfish
Administrator
#2
What about under the front seats?
Depending on the size of the amps will dictate where to fit them...
I ended up fitting mine inside the center table I built....
Could build a sub box to fit behind the rear seats and attach the amps to the box.
How about attaching to the roof liner for something different? :)
Chimestrike
The 4 channel is small enough that it used to fir under my seat in the volvo, is there much space under the seats in these as I know the passenger side has a ducket drawer, so would it fit under that? its only 40mm high ish?
Madfish
Administrator
I think there is plenty of room under there although I'm basing this on the E50...
Dont forget will need space for ventilation
chris wills
I have one amp under the front passenger seat. There isn't much room due to the seat slider mechanism. I have another under the rear seat as there is loads of space. My sub amp is also under the rear seat but built into a rack with leds too
