- Billingham
- Karl
- E50
- North East
The Elgrand was made for Japanese roads only. Due to their climate, they don't need to salt the roads and therefore they don't need to worry about underseal.
In the UK, however, this is NOT the case. Salt will eat away at the chassis and destroy your pride and joy from the inside out.
When you get a fresh import, buy from a dealer or buy privately... you MUST ensure the underseal has been done.
If buying privately, I would get it re-done no matter what the seller says, as it's sold as seen. But if you buy from a garage you will be protected by some sort of trading standards.
Underseal is basically a product that is applied to the underside of the vehicle that prevents the metal from rusting when it comes into contact with the salt and moisture on our roads. It is VITAL for a long and problem free life for you Elgrand.
There are many options available, starting at around £80 for an "in & out" service. Personally, I wouldn't touch these with a barge pole.
The best options seem to be around the £400 mark. This includes dropping your vehicle off with a garage for 3-4 days. One the first day, they thoroughly steam clean the underside of your vehicle. Second day they apply the first layer of the treatment and leave it to set over night. Day 3 they apply another coat and leave to set overnight. Then you collect on Day 4.
Also, please note that underseal is only temporary. It is not a lifelong product (unless you pay extra for a product that has a life long guarantee!). The quick £80 jobs should probably be done twice a year, at the very least, once a year.
The more expensive jobs should be topped up every 4-5 years. Speak to the professional who does your treatment for their advice as these time scales will vary depending on the product you are using.
I know a few people who are JDM car freaks who pay the £400 for a proper treatment, then £80 for an in and out treatment, and then go back and get the proper treatment re-done every other year. One thing for sure is that they will crash their cars before they rust!
