E51 OBD (Consult 2) Code Reader/Clearer Tools
Biffo
I've seen the spread sheet on what this i903 covers, but does it allow you to change any settings, ie idle speed, learn function, program keys, or is it purely just for reading codes & clearing them, also showing what the engine running data?
Nothing better than finding out from someone that has used one.
Biffo
I presently have one of these ELM327 do-da's, for a sum of £5, in conjunction with the NDSII lite ap on my phone, it reads all the codes and you can clear the codes, it also gives you the engine data as a live stream.
So if these other tools can only do similar, they're a bit expensive when this costs only £5. I'd want more for my money, so if anyone can explain anything else that the i903 can do, I could be interested also.
https://www.ebay.co.uk/itm/OBD2-Aut...243718?hash=item3acf8d3f86:g:LAQAAOSwQcJaA~xu
( PS: I believe that the updated version V2.1 will NOT work with NDSII lite - only what I've read)
Below is what I can read in real time, (There's another page full with other reading, TPS etc)
Richard Fox
Double Elgrand Obession!
I guess this is for Android phone not iPhones? :confused:
Chris T
I'd so want that on a built in screen showing every time I'm driving 😁
Garry Daniels
Yes, the budget tools are fine for detecting fault codes in the ECM (Engine Control Module for petrol engines), and for the average guy that's enough. However, there are 6 other modules within the Consult II protocol, and you probably would not need these unless you were a professional mechanic or a seroius repairer. Here they are if anybody's interested.
Biffo
There might be in the professional very expensive software, but looking further into the link that I posted early on in the thread.
http://www.obdinnovations.com/obd2-...ssan-datascan-ii-diagnostic-software-package/
Looking at the "Supported vehicles" list, you'll find that this software is only good for the ECM and SRS systems, NO OTHERS.
Nissan DataScan II software has been tested on following cars:
  • Nissan 350Z Z33 VQ35DE - ECM, BCM*, TCM, ABS, SRS
  • Nissan Almera Tino V10 (YD22DDT) - ECMD
  • Nissan Almera N16 (QG15DE) - ECM
  • Nissan Altima L31 (VQ35DE) - ECM
  • Nissan Frontier D40 (VQ40DE) - ECM
  • Nissan Maxima A33 (VQ30DE), A34 (VQ35DE), J31 - ECM
  • Nissan Micra K11 (1999 or later) - ECM
  • Nissan Micra K12 - ECM, SRS
  • Nissan Murano Z50 (VQ35DE) - ECM
  • Nissan Note E11 - ECM
  • Nissan Pathfinder R50 (VQ35DE) - ECM
  • Nissan Primera P12 (petrol) - ECM
  • Nissan Primera P11-144 (petrol) - ECM
  • Nissan Primera P12 2.2 DCI (diesel) - ECMD
  • Nissan Pulsar N16 - ECM
  • Nissan Quest 2004+ (VQ35DE) - ECM
  • Nissan Sentra 2002 SE-R (QR25DE) - ECM
  • Nissan Skyline V35 350GT (VQ35DE)- ECM, BCM*, TCM, ABS, SRS
  • Nissan Skyline V35 (VQ25DD) - ECM, BCM*, ABS, SRS
  • Nissan Stegea 350RX (VQ35DE) - ECM
  • Nissan Titan (VK56DE) - ECM
  • Nissan Xterra N50 (VQ40DE) - ECM
  • Nissan Xtrail T30 (QR20DE) - ECM, ABS
  • Nissan Xtrail T30 (YD2.2ETI) - ECMD
  • Nissan Sentra 1.8 (2001) - ECM
  • Nissan Patrol GUIII (TB48DE) - ECM, TCM
  • Nissan Elgrand E50 (VQ30DE) - ECM, SRS <<<<<<<<<<<<<<<<<<<<<<<<<<
  • Nissan Elgrand E51 (VQ35DE) - ECM, SRS <<<<<<<<<<<<<<<<<<<<<<<<<<
  • Nissan Dualis ST J10 (MR20DE)- ECM
  • Infiniti M45 (Y34) (2003-2004) - ECM, TCM, SRS
  • Infinity FX35 (VQ35DE) - ECM
  • Infinity G35 (VQ35DE)- ECM, BCM*, TCM, ABS, SRS
So, unless you've found some other 'Consult 2' software (post a link please) one wonders if it's really worth getting.
Garry Daniels
The upshot appears to be that budget tools are OK for determining engine fault codes, and this particular software is of limited value except for engine fault codes and airbag setups (possibly resetting). One thing which I am still unclear about - they list a specific module within Consult II for diesel engine codes. Does this mean the budget readers can handle diesel engine fault codes? Anybody know?
Melvstokie
I just brought this for my e51 and it won't connect to my phone did You have any issues connecting it ?
Biffo
No problem, but you have to make sure it's that particular one and not the updated version. (V2.1 or something)
I assume that you have NDSIILite V1.51 app loaded to your phone? plug in the ELM327, turn on the ign, there should be a red light showing on the ELM327, now connect bluetooth on your phone to it, then open the NDS app.
Melvstokie
Sorted got it working thanks for your reply
