E51 Multimedia box
neilloop
Im going to get a cyclone 4.
Hi @neilloop ,
Both works the same for movies and stuff, I bought M8S which I am now mostly using in my house becasue which was the sole purpose. I wanted a box with KODI so I can use in both my car and at home. If you just want to use in the car Cyclone 4 is perfect, it has miracast and it is small in size too, no troubles whatsoever, 5 mins to install, no extra adaptor/wiring required. Let me know if you need any more help. For the link, just type M8S in Ebay and you will see loads, here is the link too
http://www.ebay.co.uk/itm/2017-4K-M...584155?hash=item3ae09e74db:g:WL8AAOSw7U5Y9sZs
Regards,
KASH
Phil
No problem @Archie . Just noticed the pics have disappeared when the forum software needed updating. If you need any of the pics in my posts let me know & I'll see if I can find them.
Kash
Hi guys,
As far as my experience goes, I have only managed to get the rear screen working, no picture infront with M8S but with CYCLONE 4 both screens were working.
Regards,
Kash
Chris Riley
E52 Owner
#46
Hi guys,
Regards,
Kash
Hi all,
I have purchased a cyclone 4 but cannot get a signal to either screen. Set it up on my Tv in the house and works fine. I changed output to NTSC and still no joy. help much appreciated
MrChops
I plugged mine into the AV in of my HU and it worked fine.
Due to never using it its now in a drawer next to me. The cable is poor quality and has cracked revealing the core in several places.
Deand
Same problem with mine plug it in to tv in the house and it is fine but in the Elgrand the picture is there but its all blurred and mismatched!
Did you manage to get yours working ?
MrChops
I'm sure all mine needed was to be set to NTSC. I'll check if I get a minute to chuck it in the back seat.
Deand
Don’t know what I did but it’s working fine now!!
Its driving me mad. Cant get signal to the screens. argggg
so it set Miracast output on my tv then pluged in to av behind drivers seat and same happened. Messed about a bit and gave up just left the yellow plugged in. Get in the bus the next morning and low and behold working fine! Don’t even know what i did
Chris Riley
E52 Owner
#55
Ill try that. Maybe give her some premium fuel, a wax and see if the bus plays ball.
Chasdad
The car I've got coming has this head unit . I've got a double din sat sav head unit but I quite like the original.
It's got the rear screen . So will have the rca plugs in the back.
What's the best way to play music from an android phone and films off a Samsung tablet. Thanks
Chasdad
I'm getting an e51 soon and quite like the standard head unit. It''s got a rear screen. So it should have the rca inputs in the back.
I'd like to connect my android phone and occasionally a Samsung tablet for films. Can someone tell me what I need please
Deand
Have a look on the ICE threads there lots of info
I went with a miracast 4 from Ebay £ 39 into rear rca because didn’t want to mess up original in car it would do my ocd in!
Works great
