E51 E51 Air mass sensor or MAF
user
Looks like my MAF is nearly gone, consumption is 3-4L more than before, but idle still normal. It reads 1.46-1.50V on idle. I found replacement nr. for Maf is 22680-6n21a, but there no stock in UK, only shipping from PRC.
there is similar 5 pin MAf from primera with part number 22680-6n210 and subaru impreza/forester 22680AA290 which share intake with some nissans and e51.
Any of you replaced maf?
micky_h
Hi user
after a quick search ive found this a a replacement £23.50
<!-- m --><a class="postlink" href="http://www.aliexpress.com/item/mass-air-flow-sensor-for-NISSAN-OE-No-22680-6N21A/1192920090.html" onclick="window.open(this.href);return false;">http://www.aliexpress.com/item/mass-air ... 20090.html</a><!-- m -->
hope it helps
mike
user
Any UK stock which will work with e51? I still waiting for 2 parcels from aliexpress which I bought just after New Year, it`s why I don`t want buy from PRC (People Republic of China).
Micra, Primera, X-trail, Maxima, Almera MAFs looks same and with 5 pins. Just diferent part numbers :grin: There are couple for Elgrand, but prices ar cosmic :mrgreen:
Arctic Fox
Moderator
great thanks for the update...i am sure one of us will need this information in the future and very good to know it has worked out well.
micky_h
am sure these are the ones nissan use 0280 218 040
<!-- m --><a class="postlink" href="http://www.ebay.co.uk/itm/APD-NEW-Air-Flow-Mass-Meter-NISSAN-MICRA-0280-218-040-MAF-/330922014415?pt=LH_DefaultDomain_3&hash=item4d0c7d36cf">http://www.ebay.co.uk/itm/APD-NEW-Air-F ... 4d0c7d36cf</a><!-- m -->
mike
user
<!-- m --><a class="postlink" href="http://www.ebay.co.uk/itm/NISSAN-MICRA-Mk2-Mk3-MASS-AIR-FLOW-METER-SENSOR-MAF-1992-2010-NEW-0280218040-/161634251135?pt=LH_DefaultDomain_3&hash=item25a226f17f">http://www.ebay.co.uk/itm/NISSAN-MICRA- ... 25a226f17f</a><!-- m -->
This one even cheaper. As long they are 5 Pin ones - they fit. Now doing 25-30km more per tank with new one.
Arctic Fox
Moderator
Just to report i have replaced my original unit with the one in the link above and have got better fuel economy and has not missed a beat thanks to the owners of the previous threads
micky_h
Hi Arctic Fox
How much of a difference is there?? im only averaging 5.9 - 6.5km/l around doors 9.5 - 11 .5km/l on a run
at that price i might just change it
mike
Arctic Fox
Moderator
i would not change it as your readings are much better than what i was getting and better than what i get now
M
monoblockg44
Guest
#17
Hi all,
purchased this MAF (<!-- m --><a class="postlink" href="http://www.ebay.co.uk/itm/NISSAN-MICRA-Mk2-Mk3-MASS-AIR-FLOW-METER-SENSOR-MAF-1992-2010-NEW-0280218040-/161634251135?pt=LH_DefaultDomain_3&hash=item25a226f17f">http://www.ebay.co.uk/itm/NISSAN-MICRA- ... 25a226f17f</a><!-- m -->) off of ebay and this caused my engine management light to come on.
Anyone know of the unit needed to reset the fault code?
Thanks
Broken
#18
It shouldn't throw an error for changing the MAF. I would contact the seller and ask for a replacement.
But you need an OBD-II cable and Nissan Data Scan (I believe) to read the fault codes and reset them.
M
monoblockg44
Guest
#19
Thanks Karl - Guy came out to day and reset the fault code (£35). He also confirmed the fault was from the ebay part which is not compatible with the E51. I have sent it back for a full refund. If you look at the picture of this MAF, the resistor on the outside of the unit is missing and hence it will not work.
Just thought I would ley you guys know and stop the same mistake.
Broken
#20
That's the problem with some eBay sellers... but at least you got your refund.
I paid £80 for a MAF on an old car, and it made the car drive like a bag of shit. As it was an Electrical item, they wouldn't take it back, but offered to send it back to the manufacturer for testing. If it was proved to be faulty they would replace it. That took 4 weeks, and in the mean time I was supposed to use what exactly? Had to go elsewhere and spend another £90 on a Bosch MAF which worked the same as the original one I took off... expensive way to realise that the MAF WASN'T the problem :(
