E50 E50 headlights
I suddenly have no dipped beam headlights; irrespective of the position of the stalk it only shows Main Beam; with the blue symbol lit up when in the Main position, but the blue goes out on dip with lights remaining on High beam.
1 I suspect some kind of relay fault (all fuses seem OK)
2 If the above where do I find said relay
3 If above where do I source said relay
Any help will be gratefully received.
Many thanks in advance.
Rog Spink (hibou)
Think this box is located in the engine bay. Screenshot_20171228-222314.png Worth starting there for the relay. Can't help you with a replacement 9ne though if it's knackered.
