E50 Bad Radio, is it the cheap unit?
Charlie
My E50 came with a non decript double din fitted, all works well CD, DVD ,bluetooth etc. The previous owner had fitted a rubber aerial by the drivers mirror which doesn't work well. I've put a small 12v booster on, no improvement , then fitted it to the original aerial connector , still no good , then bought a Halfords telescopic aerial, still rubbish . Is it most likely the radio in the unit is just useless or should I persevere , I don't want to throw good money after bad on a cheap system..the radio is the main thing I want so could replace it with another cheap one that works?
Charlie
#3
Not got one to hand, will do some looking, it just seemed odd to me as every bashed up old radio in every car with a coathanger always worked in the old days, I don't need to watch DVDs or connect to my toaster at home, just have the radio on lol
Charlie
#5
Yep, that's what I want to avoid , spending money on something that doesn't fix it. I think like Madfish said I'll try another radio in and if it works it's a duff unit.
#6
Just a thought - have you got a cheap usb socket/charger plugged into a power outlet anywhere? In all 3 of my vehicles the radio reception is shite when a charger is plugged in, but fine when I unplug it! Better (more expensive) adapters seem ok, just the cheap ones that cause this.
Worth checking.
#7
Worth checking.
Good call. I have noticed that certain adaptors have given interference through the speakers as well in the past.
Charlie
#9
Update on the problem..now fixed . I bought a Radio off ebay to test , a Polar something was £12.98 delivered , removed the double din and extra wiring harness , plugged straight into the ISO connector, plugged the original aerial back in..BINGO..perfect radio, USB Ipod connection, bluetooth and a surprisingly good sound with plenty of volume, so I don't even need the Halfords aerial that cost as much as the new unit..hope the result helps someone else , back to popmaster tomorrow lol..
