E50 14 Pin Consult ECU Error codes.
Rapperfrapper
Administrator
Here is a list of ECU error codes for those who have an Elgrand E50 with a Consult 14 pin plug:
Code No. Fault Description
11 Crank Angle Sensor/Camshaft Position Sensor
12 Air Flow Meter
13 Engine Coolant Temperature Sensor
14 Vehicle Speed Sensor
15 Fuel quantity adjuster position sensor- circuit malfunction
17 Module coding plug- circuit malfunction
18 Fuel quantity adjuster/position sensor- malfunction
21 Ignition Signal
22 Fuel Pump
23 Idle Switch
24 Throttle Valve Switch
25 Idle Speed Control Valve
26 Boost Pressure Sensor
27 Engine control module(ECM)- defective
28 Cooling Fan Circuit
31 ECM
32 EGR Function
33 Heated Oxygen Sensor
34 Knock Sensor
35 Exhaust Gas Temperature Sensor
36 EGR Control-Back Pressure Transducer
37 Knock Sensor
38 Right hand bank Closed Loop (B2)
41 Intake Air Temperature Sensor
42 Fuel Temperature Sensor
43 Throttle Position Sensor
45 Injector Leak
47 Injector Leak
48 Accelerator pedal position(APP) switch/fuel injection pump position sensor malfunction
51 Injector Circuit
53 Oxygen Sensor
54 A/T Control
55 No Malfunction
63 No. 6 Cylinder Misfire
64 No. 5 Cylinder Misfire
65 No. 4 Cylinder Misfire
66 No. 3 Cylinder Misfire
67 No. 2 Cylinder Misfire
68 No. 1 Cylinder Misfire
71 Random Misfire
72 TWC Function right hand bank
76 Fuel Injection System Function right hand bank
77 Rear Heated Oxygen Sensor Circuit
82 Crankshaft Position Sensor
83 Glow plug relay- malfunction
84 Automatic Transmission Diagnostic Communication Line
85 AC relay- circuit malfunction
86 Exhaust Gas recirculation(EGR) solenoid- malfunction
87 Canister Control Solenoid Valve Circuit
91 Front Heated Oxygen Sensor Heater Circuit right hand bank
94 TCC Solenoid Valve
95 Crank Position Cog
98 Engine Coolant Temperature Sensor
101 Front Heated Oxygen Sensor Heater Circuit right hand bank
103 Park/Neutral Position Switch Circuit
105 EGR and EGR Canister Control Valve Circuit
108 Canister Purge Control Valve Circuit
111 Inhibitor Switch
112 Automatic Transmission Speed Sensor
113 Automatic Transmission 1st Signal
114 Automatic Transmission 2nd Signal
115 Automatic Transmission 3rd Signal
116 Automatic Transmission 4th Signal
118 Automatic Transmission Shift Solenoid Valve A
121 Automatic Transmission Shift Solenoid Valve B
123 Automatic Transmission Overrun Clutch Solenoid Valve
124 Automatic Transmission TOR Conv Solenoid Valve
125 Automatic Transmission Line Pressure Solenoid
126 Automatic transmission Throttle Position Sensor
127 Automatic Transmission Engine Speed Signal
128 Automatic Transmission Fluid Temperature Sensor
#2
Cracking list mate! This will be incredibly useful for those who need to know what's what :)
S
shaggy
Guest
#3
this may help also and carries on from the last on your list although I think they are generic Nissan but not sure
<!-- m --><a class="postlink" href="http://mechanicalee.blogspot.co.uk/2014/03/nissan-fault-codes.html" onclick="window.open(this.href);return false;">http://mechanicalee.blogspot.co.uk/2014 ... codes.html</a><!-- m -->
P1130 Intake manifold air control solenoid - malfunction
P1131 Intake manifold air control solenoid - malfunction
P1136 Camshaft position (CMP) actuator - bank 2 - malfunction
P1140 Valve timing sensor - bank 1 - range/performance problem
P1143 Heated oxygen sensor (HO2S) 1, bank 1 - lean shift monitoring
P1144 Heated oxygen sensor (HO2S) 1, bank 1 - rich shift monitoring
P1145 Valve timing sensor - bank 2 - range/performance problem
P1146 Heated oxygen sensor (HO2S) 2, bank 1 - minimum voltage monitoring
P1147 Heated oxygen sensor (HO2S) 2, bank 1 - maximum voltage monitoring
P1148 Mixture control, closed loop control - bank 1 - inoperative
P1163 Heated oxygen sensor (HO2S) 1, bank 2 - lean shift monitoring
P1164 Heated oxygen sensor (HO2S) 1, bank 2 - rich shift monitoring
P1165 Intake manifold air actuator switch - malfunction
P1166 Heated oxygen sensor (HO2S) 2, bank 2 - minimum voltage monitoring
P1167 Heated oxygen sensor (HO2S) 2, bank 2 - maximum voltage monitoring
P1168 Closed loop control - bank 2 - inoperative
P1171 Air leak between throttle body and intake valves
P1211 ABS control module - malfunction
P1212 ABS/TCS control module - communication error
P1217 Engine over temperature condition
P1223 Throttle position (TP) sensor 2 - voltage low
P1224 Throttle position (TP) sensor 2 - voltage high
P1225 Closed throttle position (CTP), learning procedure - voltage low
P1226 Closed throttle position (CTP), learning procedure - failed
P1227 Accelerator pedal position (APP) sensor 2 - voltage low
P1228 Accelerator pedal position (APP) sensor 2 - voltage high
P1229 Sensor supply voltage - short circuit
P1260 Injector 1 - circuit low
P1261 Injector 1 - circuit high
P1262 Injector 2 - circuit low
P1263 Injector 2 - circuit high
P1264 Injector 3 - circuit low
P1265 Injector 3 - circuit high
P1266 Injector 4 - circuit low
P1267 Injector 4 - circuit high
P1268 Injector 1 - mechanical failure
P1269 Injector 2 - mechanical failure
P1270 Injector 3 - mechanical failure
P1271 Injector 4 - mechanical failure
P1272 Fuel pressure control valve - circuit malfunction
P1273 Fuel pressure - range/performance problem
P1274 Fuel pressure - range/performance problem
P1275 Fuel pressure - range/performance problem
P1335 Crankshaft position (CKP) sensor 2 - circuit malfunction
P1336 Crankshaft position (CKP) sensor 1 - rotor teeth damage
P1400 Exhaust gas recirculation (EGR) system/evaporative emission (EVAP) system - valve malfunction
P1402 Exhaust gas recirculation (EGR) system - excessive flow detected
P1442 Evaporative emission (EVAP) system - small leak detected
P1444 Evaporative emission (EVAP) system - control valve malfunction
P1446 Evaporative emission (EVAP) system - vent valve malfunction
P1448 Evaporative emission (EVAP) system - vent valve malfunction
P1456 Evaporative emission (EVAP) system - very small leak detected
P1464 Fuel tank level sensor - voltage high
P1490 Evaporative emission (EVAP) system - bypass valve malfunction
P1491 Evaporative emission (EVAP) system - bypass valve malfunction
P1564 Cruise control master switch - malfunction
P1572 Cruise control brake pedal switch - circuit malfunction
P1574 Cruise control vehicle speed sensor (VSS) - signal variation between two vehicle speed sensors
P1605 TCM diagnosis communication line - malfunction
P1610 Ignition key/engine control module (ECM) - malfunction
P1611 Immobilizer control module/engine control module (ECM) - coding
P1612 Immobilizer control module/engine control module (ECM) communication - malfunction
P1613 Engine control module (ECM), immobilizer function - internal failure
P1614 Immobilizer control module/module coding plug communication - no signal
P1615 Ignition key/immobilizer control module communication - malfunction
P1705 AT - throttle position (TP) sensor - voltage too low/high
P1706 Park/neutral position (PNP) switch - circuit malfunction
P1760 AT - overrun clutch solenoid - voltage low
P1800 Intake manifold air control solenoid - malfunction
P1805 Brake pedal position (BPP) switch - circuit malfunction
U1000 CAN data bus - no communication with other control modules
U1001 CAN data bus - no communication with other control modules
S
shaggy
Guest
when I get back from the hospital tomorrow if I have time I will run my software and see what codes are stored and how come I can get more than 3 digits
i got the code from my car but with which software i can't remember
Rapperfrapper
Administrator
#5
I think depending on the software you use will either show up as a no like P1572, or up to a 3 digit number , but will get this clarified when I speak to a mechanic next week, as going to pick his brains about it, as he's a whizz on electrics/electronics.
Rapperfrapper
Administrator
#6
On the back of this I have found some software that may be useful to anyone with an E50 model and wanting to read the engine error codes. I already bought an ECUTALK usb lead( £70) and had previously bought an OTG(On The Go) lead and found some software called "Nissan Scan data lite 1 (free android app).
You plug in the OTG lead into your phone, then plug in the consult cable from ECUTALK, and then plug it into your consult plug. Put the ignition switch to on and start up the software on the phone and once its found your ecu your ready to run your car and check the error codes and clear them if needed, or simply monitor a number of sensors while the engine is running. I've attached a few photos of what it all looks like running.
The Ecutalk lead on its own can be run straight into a computer or laptop as well, but this idea is a little easier to use as most people use an Android smartphone.(Smartphone must support USB tethering)
OTG Lead.
OTG, ECUtalk leads all plugged into phone and consult plug and running.
Error code screen.
Nissan Data Scan Lite 1 ( for Android phones)
#7
This is excellent on a number of scales for me, as it will help with another project I am working on.
I don't suppose the cable charges the phone whilst plugged in does it?
#8
I might need to build some sort of switch to go between this and a charging cable then for my project...
#9
I'm really keen on getting a plug to connect to my laptop and run some diagnostics on the new van, could someone let me know how I can figure out what plug connector to get for my van. Are they all the same for the E50's? I've seen some bluetooth plugs for about £12 on amazon, there are 14 and 16 pin connectors, OBD-II and consult connectors have been mentioned on forum posts... Bit baffled as to which is the right one to get my hands on.
#10
Next to the engine release lever under the dash is a grey connector. Count the number of pins in it and you'll have your answer.
If yours is pre facelift (easy check - headlight consists of 4 parts, headlight, side/fog light, turning light, indicator). Then you have the 14 Pin Consult port.
If yours is post facelift (easy check, headlight is ONE solid unit). Then you have the 16 pin OBD-II port.
S
Spannerdemon
Guest
#11
Do you know what will read from this socket Karl. OBD2 reader/ scanner won't work with the 16 pin socket. Would like to read my codes if possible, but my present scanner won't touch it, despite reading other cars no problem.
Rapperfrapper
Administrator
#12
Don't buy a dedicated obd2 reader, as this will only read obd2 software which is for European cars. What you need is an obd reader that says it will read consult 2 data which is a Japanese software, although your car may have what looks like a 16pin obd2 plug , your ecu uses consult software.
Hope this helps a little
S
Spannerdemon
Guest
#13
Thanks Rapper. Starting to vaguely understand it.
Simon has put a post in just now on my other thread re this. He may well have some ideas......
